I have a k301 in a 129 that I can not seem to get to run right.It idles fine, wide open is fine. But it stumbles real bad when trying to accelerate to the point it will stall. If I pull the choke out it will accelerate. High speed needle looks fine, new points, valves adjusted,carb cleaned and adjusted no vacuum leaks.. I have tried everything!!! any ideas?
Is your GOV set up right?
Love the model 100! |
Just my guess but if you need to pull choke in order to get it to accelerate I'd say it's running lean. I'm sure the guys that know more about the older engines than I do will chime in.
have you ever taken it apart and cleaned the carb? there are several areas that will hold dirt, the brass tube that threads up from the bottom like to accumulate dirt behind it. sometimes the idle circuit holes in the needle get stuff in them. have you ever tried to richen the idle and hi speed screws?
anytime you take the carb off you should adjust the governor to the carb since its rare you ever get the carb bolted on in the same spot |
Yes I did per the Kohler site..
Yes adjusted high and low. No I never took it completely apart maybe that's it... I will give that a try Thanks guys.
just so you know ; when kohler gives you its preset turn's out. that's not the actual setting. just a starting point. your engine or any engine may need to be turned in or out a half turn to a turn to actually get the setting correct.
