Old 12-14-2013, 12:51 AM
austin8214's Avatar
There is only one type of Kevlar disc to my knowledge. You should be able to slip it a good deal but without the extended release arm clutch control is more difficult.
Old 12-14-2013, 05:04 AM
cubby102's Avatar
cubby102 cubby102 is offline
I've never had a issue with bone stock clutch in good shape even beating on it
Old 12-14-2013, 07:03 AM
garnold's Avatar
garnold garnold is offline
Wow thats some game of tug-o-war!
Ok im pretty sure at this point stock is going to be just fine :-)
Old 12-14-2013, 10:58 AM
Merk Merk is offline
It is easy to spin tires-put the tractor to work.
Put a set of ag tires on, add 100 to 150 pounds and them hook a moldboard plow on it. Them go plow some Northwest Ohio soil. This soil will make a tractor that can pull a 5 bottom plow be lucky to pull a 4 bottom plow.
You will have clutch slipage with a stock spring. I'm using a spring from a New Holland/AGCO cultivator. It is a 500 pound rated spring. Stock spring is 200 to 250 pounds. You will have to use a spacer between the driveshaft and inside the spring. Part number for spring is PECP1511A1 (New Holland) and EP1511 (AGCO) . Because of the spring length the spring has to be cut into 2 pieces....you get 2 springs out of it.
Cub Cadet Classics sell a blue spring that has the same tension as my cultivator spring set up. My clutch set up has been my hop up 100 for 4 years.
I aslo use a kevlar clutch disc because the price and it has less slippage.
I aslo replace all the pins and bushing in the clutch driver. I will use a split collar instead of a pin to hols the main spring in place. THe hole in the driveshaft makes a weak spot in the driveshaft.
My clutch set up may be overkill.....I prefer to build it once and not be afraid to push the limits.
My Uncle Dick topic has a clutch rebuild section in it.
Project Uncle Dick
Cub Cadet 70
Old 12-14-2013, 02:36 PM
cubby102's Avatar
Yea that pic was taken after the work had been done loaded tires with about 3 psi in them pulling a 125 with 3 of the four wheels locked up I just started to have fun at that point. I havnt had it slip the clutch yet that day was 3rd gear 3/4 throttle I ran out of traction or engine before anything
