Old 12-02-2013, 06:50 PM
So, you are saying, with the Blue Wire off the V/R, as soon as you rotate the Ignition Switch from off to on, the S/G is energized...??? Right...???
Old 12-02-2013, 07:20 PM
gnufe's Avatar
gnufe gnufe is offline
Yes that's right.. So I got to play a little more tonight.. Ohmed the old switch out and it was working right. Removed the switch in it and it was newer and still had writing on the back for bat, ign and st. Traced wires from ign and solenoid to plug for switch and found the ign and start wires swapped.. Swapped them in the plug, put the switch back in and turned it over and it turned over when the key was turned to start and stopped when turned back to run.. Checked to see if it was firing, added some gas and with a little choke, it fired right up.. Hydro works, pto looks like it will work, it charges, now to get the electric lift and lights to work, tires to hold air and a seat and it should be a good back up mower after a tune up and fluid change..
Thanks for all you help!!
Stuart
Stuart in Hopkinsville, Proud owner of an Original, 100, 73, all of which belonged to my dad, 125 with lift, hitch and 1a tiller, 126, 147 also have a 1961 Bolens ride-a-matic, a case 222 and a case 446.
Old 12-02-2013, 11:01 PM
Great news!
Old 12-03-2013, 02:03 PM
gnufe's Avatar
Hi all,
I have another question now.. On the electric lift, there are two wires that go to the lift motor and on my tractor there is a blue wire that comes from the key switch and a white wire that I think goes to ground. Where do these plug into the lift switch?
Thanks,
Stuart
