Old 12-02-2013, 10:23 PM
vartz04 vartz04 is offline
Mine I think is 6 amps at full load. Its hooked to the standard cub set up for power with a Dpdt reversing switch.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 12-02-2013, 10:26 PM
garnold's Avatar
garnold garnold is offline
I haven't looked that deep into the wiring diagram for my 108. When you say standard power area you saying there is an aux power setup or something else?
Old 12-02-2013, 11:05 PM
Nope. Hooked to the battery. No modifications to the battery or charging system to run it
Old 12-02-2013, 11:07 PM
garnold's Avatar
Cool. Thank you. Would you mind linking to the model you're using please. Very helpful thread. Thanks
Old 12-02-2013, 11:12 PM
Not sure of the exact model I'd have to go take it off the tractor to see the serial number/model number. Its a 1000lb 4" stroke linear actuator. Anything 500-1000 lb and 4-6" stroke will work.
Old 12-02-2013, 11:17 PM
garnold's Avatar
Some good stuff here I think.
http://www.surpluscenter.com/shop.ax...words=Actuator
Old 12-03-2013, 10:34 AM
Muzzy Muzzy is offline
I put a narrowframe hydro on my 147. It's not a simple bolt on by any means. Unless your mechanically inclined and have a good shop, I'd go with another option.
Old 12-03-2013, 05:15 PM
gpapa gpapa is offline
Thank you all for taking the time to answer my post. Not sure what I will be doing, but I know the white stuff will be on the ground soon enough.
Old 11-25-2015, 10:27 AM
dcooke570 dcooke570 is offline
Buy a new actuator. I made my own electric lift for my 104 and it works great.
Excuse the dirty deck
I'm thinking of stealing your idea and doing the same thing on my 104. Have you had any bending issues with that bolt on the bottom of the actuator next to the generator? With a 1000 lbs on that bolt I wasn't sure how it has held up over the years.
My son built me a box scraper that weighs 175 lbs and it takes the both of us just to lift it off the ground using the existing lift lever!
Dan
Old 11-25-2015, 11:50 AM
ccr147 ccr147 is offline
I like the elift but the worst thing is fixing them when they break. I put new bearings, bushing, brushes in the motor on mine then the spiroid gear went. I haven't fixed it yet as I'm contemplating selling it and putting a winch on the tractor to raise and lower implements.
Curt
