Old 11-26-2013, 09:39 AM
OldAndInTheWay's Avatar
Originally Posted by Rdrnek View Post
also I think some of the 1450s had a hydro output on the front for a power angle plow and such.
I got one. The dual hrdro was an option on all the hrdro QLs I think.
Old 11-26-2013, 10:08 AM
The 149 pretty, the 1450 ugly jusy my 2¢
They both use different keys
hehehe
Old 11-26-2013, 11:32 AM
wally67's Avatar
wally67 wally67 is offline
I have owned both and would take the 149 over the 1450. I really didn't care for the ISO mounts in the 1450 any thing between idle and full throttle the tin work vibrated horribly and that was with new ISO mounts, but the 1450 was a little smoother at full throttle than the 149. If you do get a 1450 closely inspect the ISO mounts and drive-line before you buy it I made that mistake and cub parts aren't that cheap
Wally
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow.
Old 11-26-2013, 12:33 PM
jimbob200521's Avatar
hehehe
I beg to differ, aside from the side panels. Those things are uuuuuuugly. But the rest is pretty similar to the 149, plus I like the hydro control on the right hand side.
Wally
This is great advice; check the mounts. I recently, after much hesitation, became a Quietline owner. My mounts need replaced and my engine cradle needs the brace welded on but thanks to (many, actually) helpful members here, that was made short work of. The brace, fyi, is optional, but much much preferred as it'll add life to your ISO mounts. The ISO mounts, depending on which route you go, will set you back about $20 a corner for a total of around $80 in parts. Aside from that, when properly maintained, the Quietline series is as good as any other Cub, hands down. And they seem to be very popular, to boot. I see them online for sale all the time.
-Ryan
Old 11-26-2013, 12:42 PM
All good points. Both are great machines and will work circles around anything in their class.
The Quiet Line tractors were very different from the earlier model Cubs. About the only parts that are the same between the Q/L series and 1X8/9 tractors is the transaxle and a few pieces of tin.
With a Q/L tractor, if you intend to end up with "no problems" worker, you will want to pay special attention to the drive shaft and related parts.
What happens is that the rubber motor mounts become crushed over time and cause the engine to set crooked in the frame. This causes the drive shaft to become out of align with the transaxle, then the connecting parts wear quickly. To the best of my knowledge the rubber mounts and the parts that wear out or break are pretty expensive.
The 149 doesn't have these issues, not that it doesn't have parts that wear, because it does. There are just fewer parts and much less expense.
There is the possibility that the PO of this 1450 has already replaced the mounts and drive line parts and that is why the tractor is "somewhat pricey".
A Quiet Line tractor that is in good mechanical condition, should run quietly with little to no vibration and very few rattles. If the engine shakes and the tin vibrates, then there is probably much work and expense in it's future to correct the problems.
Good luck with your decision.
Old 11-26-2013, 01:04 PM
red56turbo's Avatar
[QUOTE=jimbob200521;227920]I beg to differ, aside from the side panels. Those things are uuuuuuugly. But the rest is pretty similar to the 149, plus I like the hydro control on the right hand side.
The bad thing about the hydro handle on the right side is you need two right hands to move the hydro lever and move the hydraulic lift lever......
That's why they moved the hydraulic lift to the left side on the 782's. Pretty much out of luck with the manual lifts.
Josh
Diesel Cub Cadets...........
Old 11-26-2013, 02:20 PM
That's funny, I've always desired the look of a QL than a 1X8/9 series.
Old 11-26-2013, 02:28 PM
TheSaturnV's Avatar
Reminds me when I hear someone say the P47 is ugly.....
Old 11-26-2013, 02:51 PM
SS5150's Avatar
SS5150 SS5150 is offline
How do you check the iso mounts if you were looking at a tractor for sale?
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 11-26-2013, 02:57 PM
You put your hands on the engine, and push it to see, if it moves. If the engine moves, the mounts need to be replaced.
