Old 11-23-2013, 03:03 PM
Cub Cadet 1650's Avatar
Cub Cadet 1650 Cub Cadet 1650 is offline
Default Cub Cadet 129 problem
I bought my 129 a couple months ago and have been working on it as much as I can, it has had its fair share of problems (wrecked cylinder from a thrown rod, rats nest of a wiring harness, bad steering, and nasty paint job). I've put in a different motor and wiring harness along with a new solenoid and key switch and amp meter. Yesterday I finally got to hear it run but there is one little problem. I have to keep holding the key switch to the starting position to keep the motor running. If I try to start it like I normally would it will start up but not keep running. I think it may be the key switch. I have all the wires hooked up right so that seems like the most likely thing to go wrong. I just want to know what you guys think about it.
Cub Cadet
102
106
122
124
1250x2
1650
Old 11-23-2013, 05:42 PM
OldAndInTheWay's Avatar
I had that problem.. Reverse the wires on the amp meter fixed mine I think... Something simple like that.. Very frustrating.. I spent hours trying to figure it out.
Old 11-23-2013, 09:17 PM
Sounds like it isn't wired correctly..... or you have the incorrect key switch.
Old 11-24-2013, 12:38 PM
Its wired right I bought a service manual off ebay and followed that. I also have the right switch because it along with the wiring harness are from cub.
Cub Cadet
102
106
122
124
1250x2
1650
Old 11-24-2013, 12:41 PM
The only thing left is a BAD Ignition (or key) Switch.
Old 11-24-2013, 06:38 PM
gmbadgley gmbadgley is offline
Take a test light and check the system, in a few minuets you will have your answer.
"If I can't fix it, I can screw it up so bad no one else can either"
Old 11-24-2013, 07:24 PM
Positive side of coil needs to stay positive 12v after start in "run" position. Comes from "ign" terminal of keyswitch.Mr. Badgley is right on the money here, Gotta test it and see what's happening.
