Old 11-06-2013, 12:04 PM
VIOLATOR VIOLATOR is offline
Default Ideas for a plow
Howdy all,
I am fixing up my plow for my 1650. It needs a new wear bar. Does anyone have any ideas for a cheep replacement. The onest that i have found are all around $60. I called the local welding shop by me and they can get me a piece of mild steel 42'' x3'' for $20. I was thinking about going with a high molecular weight plastic but that was expensive. Does anyone have any ideas on plastic vs metal?
Old 11-06-2013, 12:46 PM
vartz04 vartz04 is offline
Look at my thread a few down from yours about the rubber plow edge
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 11-06-2013, 12:55 PM
extrememotorworks sells them ready to bolt on for like $40
Old 11-06-2013, 01:56 PM
and the plastic edges for like $20. They have some cool stuff.
Old 11-06-2013, 09:15 PM
gmbadgley gmbadgley is offline
You can always call a heavy equipment contractor near you and see if they have any worn out cutting edges from a small dozer. that would last the life of the blade.
Old 11-07-2013, 07:19 AM
edw's Avatar
edw edw is online now
Default blade edge
Being cheap I picked up a 4 ply tire casing cut the tread out and bolted to my blade and so far has worked good. I mounted it between metal cutting edge and blade mouldboard but had to use longer bolts
Ed Wells
Jeffersontown Ky
Old 11-07-2013, 08:05 PM
Have you tried turning unbolting it, turning it around and using the other side?
Old 11-13-2013, 12:39 PM
Thank you all for the input. I have decided to go with A mild steel blade. I got a piece of steel from a local welding shop. I painted it and used some stainless steel bolts to assemble it. I'll try to get some pictures posted. My phone is giving me problems.
