Old 09-06-2013, 08:00 AM
bullockcm bullockcm is offline
Default Jeff in PA sleave hitch adapter question
Anybody know what size bolts Jeff's adpater uses for tightening up the implement to the hitch? I think they are 1/2" but not sure. Also how long should the bolts be?
For that matter I am new to this stuff and know I have seen some discussion on whether or not to use them with a moldboard plow. Any thoughts? What about with a cultivator?
Last question, if you don't tighten them up like some have suggested when using a plow do you need to use a "jam" nut or something to hold them in place and keep them from backing out?
Old 09-06-2013, 09:33 AM
ravenseye ravenseye is offline
I'm pretty sure that you only use the implement pin when attaching the plow to the sleeve hitch adapter. My understanding is that the plow needs "wiggle" room. I think the pin diameter is 5/8" and it's about 4 1/2" long. I bought one of the kind with the red handle on top so that I can just drop the plow to the ground, pull the pin and it's all set. I'm not sure about a cultivator so others can help in that regard.
Old 09-06-2013, 08:00 PM
The nuts are 1/2-13NC for the bolts.
