Old 08-20-2013, 03:42 PM
druwl druwl is offline
Red face Electrical IH CC 1250
So I got my 1250 lubbed up and decided to spin the engine a few times. After a few unsuccessful attempts and finally getting the battery terminals hooked up correctly.... lol She's spinning like a top! Unfortunately I had to hot wire directly to the starter. I went back to the solenoid and hot wired from the battery post on the solenoid to the small switch wire and she spins.
I've checked the fuses and have the safety switch depressed.... Got nothing with key. The lights are gone so no help there.
Without... a meter how can I check the switch wire from the solenoid to the key switch?
Old 08-20-2013, 04:15 PM
The LH brake Pedal has to be depressed as well as the PTO Switch has to be in the OFF position.
IF the above is done, then you have a bad wire, wire connection, or bad device.
Go to the Technical Library Section on page #5 and get the Q/L wiring diagram.
Old 08-20-2013, 04:33 PM
And get a test light or a meter. I believe they sell BOTH at Wal-Mart......... Doing electrical work without the tools is like changing a tire without a wrench.
Old 08-21-2013, 08:40 AM
Whizdbiz2 Whizdbiz2 is offline
Agree with J-mech, meters are cheap and a whole lot of help, not just with Cubs but all kinds of machines and around the house too.
Cub Cadet 86
Mahindra eMax 22 w/FEL
Husqvarna LGT2554
John Deere GT275
'48 Ford 8N
'41 Ford 9N
Yerf Dog Scout CUV
Old 08-21-2013, 10:38 AM
RChristensen RChristensen is offline
Inactive Member
Any time a Quietline starter doesn't engage the first thing I try is to wiggle the PTO switch. They have a bad habit of getting intermitten. Hold the starter switch on and wiggle the PTO switch, and they often find a spot where you get a connection.
Old 08-22-2013, 11:44 AM
I do have a test light. So far everything checks. I need to check the PTO switch tonight.
Old 08-24-2013, 12:03 PM
Okay!
I got elect to the PTO switch but nothing coming out. I hot wired around the switch and she spins.
Is it worth it to try and clean the switch or should I just get a new one?
Old 08-24-2013, 12:19 PM
I'd try cleaning the terminals first. Unless you have been having trouble with the PTO engaging. If so, it probably needs a new one. Sometimes a little sandpaper does the trick!
Old 08-24-2013, 02:24 PM
Nightow1 Nightow1 is offline
I had sort of the same problem with mine, I went through all the terminals and cleaned them up + blew out and used some fine grit sand paper on the female block connectors, and BAM it started right up, and my lights finally worked LoL. But a meter is definitely worth the few bucks and it saves a lot of time.
good luck!
Old 08-24-2013, 03:09 PM
rmunro's Avatar
rmunro rmunro is offline
Nobody has mentioned.
To diagnose and repair electrical problems, often a large bottle of aspirin is necessary. Or MANY
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
