Old 08-22-2013, 07:35 PM
bsb369 bsb369 is offline
Default K161 Stop Pin
I'm working on my K161 in my 1961 original and no matter what I did I couldn't get the governor to set properly. I started looking at the engine for possible causes and noticed that the PO had apparently stuck a bolt in the block where the stop pin goes. My question is can I install the proper stop pin in without tearing the engine down and could this be the cause of my engine wanting to run wide open? As always thanks for any help.
Old 08-22-2013, 08:57 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
on a 161 the stop is behind the governor arm, you loosen the brass nut and rotate the stop to adjust the speed. check the manual if you're not sure. you can down load it at kohler engine site
Old 08-22-2013, 09:21 PM
ok well there is a threaded hole near the cross shaft that has pin type phillips head screw in it. What is the purpose of this screw?
Old 08-22-2013, 09:31 PM
dvogtvpe's Avatar
that keeps the governor gear from falling off of the pin inside the engine.
Old 08-22-2013, 09:36 PM
oh ok....well that doesn't sound good....can I install it without tearing the engine apart? That would probably explain why the governor isn't working?
Old 08-22-2013, 09:42 PM
dvogtvpe's Avatar
if the governor fell of the pin inside you will have to at least take the pan off, I've changed them on 10 and 12 hp Kohlers with the engine assembled and its time consuming but never tried on the smaller ones.
Old 08-22-2013, 10:00 PM
I found a picture online of the screw I'm talking about. Its the long screw about the brass nut in the picture
File Type: jpg $T2eC16RHJIUFHHVOZk1mBSFkDM,tPQ~~60_57.jpg (19.2 KB, 49 views)
Old 08-22-2013, 10:17 PM
dvogtvpe's Avatar
yep, that's the one that holds the governor from falling off of the pin that it rides on
Old 08-22-2013, 10:20 PM
I was afraid that was what you were going to say lol. Thank you for your help I really appreciate it
Old 08-22-2013, 10:28 PM
dvogtvpe's Avatar
if the governor assembly did fall off it possibly did other damage. it drives off of the cam.
