Old 08-19-2013, 10:22 AM
greg9168 greg9168 is offline
Default Need drive shaft for SGT 1882
I finally figured out that the problem with my 1882 is the driveshaft. The splines have failed on the end going into the engine. Does anyone out there have a used one or know a source? I checked the sites on this forum and it appears they dont have one. Thanks for your help.
Old 08-19-2013, 12:39 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Sounds like you could be in line for the driveshaft update that Mac had worked out. I have the "prototype" on my 1572 and it works GREAT. No more rag joints and no more in-line clutch. This could probably work on your 1882 as well, and even simpler since I believe all you need is the shaft that goes between the adapter plates on the engine and the hydro pump. I think Mac used a 3000 series driveshaft for it. Mac?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-19-2013, 02:04 PM
Can do just need the dimension between the pump adapter and the engine adapter. I use the 2000 series shafts but they are the same as the 3000 series. Did you check with Patton?
Old 08-19-2013, 06:14 PM
Oak Oak is online now
The 1882 uses the CV type shaft.
Old 08-19-2013, 07:39 PM
Yep
Old 08-19-2013, 09:41 PM
FrankF3's Avatar
And a shortened 2000 series drive shaft of the proper length should bolt right in, using the round rubber/neoprene snubbers which require no maintenance/greasing.
Old 08-19-2013, 09:49 PM
Wow, that's pretty crappy. You gotta buy the complete shaft for over $300. I was thinking they still made a replacement driveshaft only.
Old 08-20-2013, 06:58 AM
You can still get the shaft only for some tractors but Cub is playing gotcha on a lot of them. This is a 2000 shaft I put together using a 1772 that some guy from GA has sitting in my shop to mock it up.
Tags
1882, drive shaft
