Old 08-19-2013, 03:06 PM
moose007's Avatar
moose007 moose007 is offline
I believe the shaft it self broke. First thought was the pin, but under further investigation the shaft appears broken.
1967 IH Cub Cadet 125 w/ hydro lift, hydo option in front, 3 pt, and 38" deck
Old 08-19-2013, 05:58 PM
Where in WI are you located?
Old 08-19-2013, 08:51 PM
moose007's Avatar
Seymour, Just west of Green Bay about 15 minutes
Old 08-20-2013, 12:31 PM
Have to get together sometime, I'm up in Gillett.
Old 08-20-2013, 03:15 PM
moose007's Avatar
Yes we will, you are not that far away!
Old 08-20-2013, 08:01 PM
moose007's Avatar
I have been looking closer at this so I can take it part to fix it. How do I get the belt off that runs the deck? The lever that engages and disengages the clutch is in the way from what I can see. The reason I am asking is so when that belt fails and needs replacement I know how and also I want to drop the carriage to make it easier to work on. Any help would be greatly appreciated. Thanks
Tags
125
