Old 02-18-2010, 08:32 PM
electricmonster's Avatar
electricmonster electricmonster is offline
Default Electric Implement Lift
Thought you all would find this little project I did interesting. I was frustrated w/the lack of availability and/or cost of a factory lift. So I build one myself. My goal was to build something that would not involve "hacking" up my machine.
I bought the lift used. It is a 1000LB rated Warner electric unit. I painted it and mounted with a bracket & bolts to the frame. I attached to the lift assembly w/a hitch pin. Constructed a wiring harness from automotive grade wire & a fabric loom. I wanted a joy stick because I may at some point try and build an electric power angle. The stick is 4-way. To use a joy stick, I had to build a relay setup (2) w/2P 2T relays. I had a hard time finding them. Purchased from MSD ignition via JEGS Speed Shop. Mounted a watertight aluminum project box under the seat to house. All is protected with a 30A circuit breaker. All terminations are heat shrunk. I found the leg guard used for $4.50.
It works awesome! I plowed for hours. I do have a spring assist on this. However, I'm sure it would work fine with out it. It was a fun project.
Old 02-18-2010, 10:14 PM
TEET's Avatar
TEET TEET is offline
Well done! Looks like it will work well... :biggrin2.gif:
Do you know what the lift was on originally? Like a wheel chair lift or something?
CCC 1211
71
127
102
122
1962 Original
Old 02-18-2010, 10:29 PM
That's cool! Nice job!
Old 02-18-2010, 11:23 PM
I like that, awesome job!
Old 02-18-2010, 11:27 PM
ihnick's Avatar
ihnick ihnick is offline
cool thinking. that would possibly work on a wideframe and newer geardrive huh?
Nick.
Old 02-19-2010, 01:26 AM
Very nice, electricmonster, very nice!
Old 02-19-2010, 07:42 AM
electricmonster"
Excellent
Old 02-19-2010, 09:00 AM
1cub2cadet3 1cub2cadet3 is offline
Nice job.
Since my 123 is in pieces this would be a nice add-on. What is the stroke on the actuator 4",6"? Can you provide any other details on the part number for the joy-stick? Any info would be appreciated. Like the old saying goes, 'Imitation is the highest form of flattery...' Thanks!
Old 02-19-2010, 09:27 AM
The original lift had specifications of: 500 lb lift capacity and had a 6" stroke.
Old 02-19-2010, 08:57 PM
Great engineering!! Sounds like it is your forte Electricmonster.
