Old 07-22-2013, 12:57 PM
machinehead323 machinehead323 is offline
Default installing rings
im about to begin putting my K341 back together. can i install the rings by putting one end of the rings in the groove and working it down and around or do i need to use a ring expander. i cannot find one in town. i am using original kohler rings.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 07-22-2013, 01:09 PM
Do you have a flat tipped snapring pliers?
That's what I used on mine.
Dave S
Old 07-22-2013, 01:25 PM
It's better to "expand" the rings. I just do it by hand.... Snap ring pliers are a little easier on the fingers though....
Old 07-22-2013, 02:53 PM
i do not have any flat tipped snap ring pliers. i have many that are different sized rounds, and a universal set with replaceable tips. there is a large gap in them though. with your out of the box thinking to get my brain going i could take two flat head screwdrivers and put the tips together and they expand when i close the handles. maybe a little rubberband wrap at the tips?
Old 07-22-2013, 03:03 PM
cubfixer's Avatar
cubfixer cubfixer is offline
I've put on a bunch of rings by hand. Just start them on the top of the piston, and gently work them around until the end of the ring goes into the 1st groove. Work it out of the groove before the other end gets into the top groove. Then do the same to the second groove. Then work it out of the second groove into the third groove. Don't allow the entire ring to fit into the groove until it reaches the groove it belongs into. Then install the oil ring then the last ring goes into the top groove. It should just take a few seconds when everything is going good. I was always cautioned against expanding the rings too much, since they may either expand too much or break.
I am sure that other members may have different advice. I used to build chevy and ford race motors in the seventies.
John
Old 07-23-2013, 10:03 PM
Sugarmaker's Avatar
I think they do make ring expanders, but I have put most of mine on like John describes.
Regards, Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 07-24-2013, 11:55 AM
Rings are not supposed to be installed this way. They can "twist". You are supposed to expand them and install them. DO NOT "roll" them on. It even says that on most ring packages, AND most service manuals. You can do it by hand, just expand them, don't roll them.
Old 07-24-2013, 07:05 PM
Here's what they look like. These are Perfect Circle tools
Old 07-24-2013, 07:34 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
if they twist they stick in the ring groove of the piston, this equals no ring seal. be real carful putting the oil ring on, they are just cast iron and can break easy
