Old 07-15-2013, 07:27 PM
Originally Posted by MattinmMichigan View Post
I was responding to what Sam asked for
That's fine..... My answer is the same, even with that info.
Old 07-15-2013, 08:25 PM
For a rebuild kit, I have had really good luck so far with the aftermarket kits off Fleabay. I have used two so far and have been impressed with how these engines run with them. If it were mine I would get the engine apart, see what sizes your rod and piston are, and order a kit. Give the cylinder a decent honing and you are back in business. If the cylinder is grooved, well, thats a different story.
Old 07-15-2013, 11:27 PM
X2
Old 07-15-2013, 11:59 PM
X2
I figured I would get a rear end chewing from all the diehard kohler lovers for mentioning this! haha
Old 07-16-2013, 12:00 AM
Kohler parts are getting really expensive..... won't be long before this is the ONLY way you can go. I, am personally fine with non-OEM parts!
Old 07-16-2013, 01:56 AM
I was hoping that it might be heat related, clogged fins or out of time. Causing the oil to thin badly; that coupled with an old engine will also cause puffing out the breather.
Probably best to remove the head and see what you find in there.
Old 08-09-2013, 10:54 PM
MattinmMichigan MattinmMichigan is offline
Well J-Mech you were dead on on your diagnosis the cylinder is scored bad and it is a .030 over engine . I am going to have look in my spare blocks with a virgin bore and go thru it I guess I have one block that has a virgin bore with a broke rod that is the same vintage as the existing engine can I go ahead and swap out cranks if it is in spec clean up the internals ? can I use my old rod or is that a no no
Old 08-09-2013, 11:24 PM
cubby102's Avatar
cubby102 cubby102 is offline
I would go ahead and do both rod and piston. For what little the kits cost with and without the new rod its good insurence to just replace it I have used the ebay kits for 3 engines now and the k301 on my 124 has about 100 hours on it and I dog it hard with a 48 inch deck and tall grass. And she still just grunts and comes to life. I have noticed a little puff of smoke every now and then but its also over due for a oil change.
Old 08-10-2013, 12:16 AM
Well, I'm not sure what to say.... Um... your welcome? Or, I'm sorry? LOL..... unfortunately, in my line of work, I have to "break bad news" a lot. Still, it sucks you have to rebuild
I have seen the price of the e-pay kits, and I'll be honest, I'm going to buy one! Like cubby102 said, the price with the rod is just a few bucks more. I don't recommend using the old one. It's a no-no. Since they don't have bearings in the rod, it functions as such. Using it over is like rebuilding a chevy 350, but using the old bearings again. Good luck! We'll be here to help if you need it!
Old 08-10-2013, 10:40 PM
sawdustdad's Avatar
I had very similar symptoms week before last with my 108. Scored cylinder and worn piston. Being bored and rebuilt.
