Old 07-04-2013, 10:45 PM
Default Conversion
Got a question that I was wondering....Can a 123 be converted to take on a Quick Attach undercarriage to retro fit a QA deck? I know that almost anything is possible, but I was wondering just how much trouble it would be to do it.
Old 07-05-2013, 06:49 AM
The "Quick Attach" feature is welded to the frame. Thus, you would have to (A) Cut one off a "QA" tractor, or (B) Fabricate this item, then......weld this to the underside of the frame.
Old 07-05-2013, 03:24 PM
mmzullo mmzullo is offline
Do you want to convert the 123 to QA or can a QA subframe be used on a 123? Roland has the answer. But you can use a QA subframe on a 123 but has to be bolted to the frame.
Old 07-05-2013, 04:50 PM
IHinIN IHinIN is offline
You should be able to use the QA deck subframe with your bolt on mule drive.
Old 07-05-2013, 04:56 PM
Dad has a 125 that someone cut the QA OFF so he had to bolt on a mule drive from a 123- works but it looks silly.
Old 07-05-2013, 11:35 PM
That's what I was wondering. I have several QA mule drive subframes and decks, but only one pin on dec and subframe. I came across an extra 123 and may sell it, but wanted to sell it as a mower. Thanks so much for the help and advice in this area!! I hope to post some pics of my newly acquired 123 soon.
