Old 07-02-2013, 10:05 PM
vartz04 vartz04 is offline
I think these old tractors were more fun r gardens and less for mowing. I can bog my 10 hp easily in second while mowing. My dad's x595 hogs through the same grass like it's nothing.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 07-02-2013, 10:27 PM
rweaver rweaver is offline
I think we are talking on 2 sides of the fence I get to use both old and new to mow with the newer units handle the deeper decks and I think that's where some of the design changes do better do I think newer is better not in every thing and I also think they raised the wing tip speed which helps in the cutting and helps against bogging
Old 07-03-2013, 12:56 PM
Here's my take:
1960s-70s Garden tractors were made to be tractors, and tractors at that time get the job done efficiently because they were slower; farming was slower.
Todays world is GO GO GO GO GO GO GO %1000 of the time and (most) people don't want slow and effective, they want fast and effective.
I'll take slow. I don't need my driveway plowed or my grass cut at Richard Petty speed. I also think it has to do with better torque of the old machines.
Old 07-04-2013, 08:45 PM
steveyrock's Avatar
steveyrock steveyrock is offline
I just bought an Exmark zero turn with a Kawasaki 23 HP motor.The machine has tremendous blade speed and will cut very well at the highest ground speed which is very fast at full throttle.
I love to mow with my old cubs and they do cut very nice but the Exmark is simply a yard tiger when you need to get it mowed fast, even wet grass.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
