Is the shaft that connects the main frame to the sub frame (on a front mounted blade) supposed to be free, or welded to the main frame?
Thanks
here is a picture from the parts lookup.Are you talking about #12? This was easy to find...
No, I was talking about the rod that connects #10 to #9 or #22 to #16.
The shaft on #16 is welded to #16, yes.
Thank you. I didn't know if it was an IH thing or if a PO did that.
Mine is welded, probably by the PO. Works just fine. Until I need to change out subframes! Just slightly harder to install the subframe with the blade welded to the subframe.
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
I don't think it was a PO that did that. Mine is welded as well. I took the subframe off for painting and it was slightly a PITA. I can't wait till I can try to get it back on again.....
They are easy to pop on and off after you do it a few timea. A straight claw hammer or crowbar makes it real easy. Apparently gonna have to be real carful with freshnpaint. And expect to touch upnpaint.
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
![]() Quote:
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
I appreciate everyone's responses, and tips. The blade's a worker anyway, so I'm not too concerned about some scratched paint. I am just looking for a look that is not all-rust (like it currently is.)
