Old 06-22-2013, 02:25 PM
cdlong's Avatar
cdlong cdlong is offline
Default 1450 cranks, but won't start.
I used this tractor every weekend to mow. Went out today & it cranked, but wouldn't start. I changed the coil, wire & condenser. The Chevy points look good. I also changed the voltage regulator. All parts came off my other 1450, (yes, it ran before I took the parts off). I only have 2-4 volts of current @ the neg terminal of the coil. when cranking the engine on the 1450 that won't start. The battery has 12 volts. The 1450 that runs has 10-12 volts on the neg terminal of the coil. I'm completely at a loss here. I have unhooked the wire from the coil to the points and ran a jumper from the battery to the points, still won't start.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 06-22-2013, 02:58 PM
Run a Ground Wire from the Battery Negative Terminal to a good clean spot on the Engine block.
Old 06-22-2013, 08:17 PM
cdlong's Avatar
Some will say I'm full of it and some will say, been there-done that. I was figuring on removing the tiller from 1450#2 and putting the 44" deck from 1450#1 on it. I told the Lord I sure needed the tractor to run. He said "file the points". I did and bam, it fired right up and ran fine.
Papaw
Old 06-22-2013, 10:10 PM
Glad you got your cub to fire up!
Old 06-23-2013, 07:24 AM
X2!
Old 06-23-2013, 09:01 AM
Grampie Grampie is offline
Well cdlong, I'm glad it's running for you and I believe you ask the right one for help!
Old 06-23-2013, 12:04 PM
PaulS's Avatar
PaulS PaulS is offline
God does like cub cadets otherwise he would not have made eggs yellow and white. Glad you got the msg to get your tractor going. So many times it is something simple but with electrical systems you have to find it first.
