Old 06-05-2013, 09:20 AM
fleetlines's Avatar
fleetlines fleetlines is offline
The frame is in the electrolysis tank. It will be done today. The steering cleaned up well. When I saw that brake I figured it needed replaced (like a cars pads soaked in grease). It cleaned up well and I believe it is alright for a little, slow tractor. That grease has to go somewhere and both carriers were pretty full. I don't recall carrier clean out being on the regular maintenance schedule. I still haven't ordered any parts yet.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 06-06-2013, 10:32 AM
fleetlines's Avatar
The trany and frame are in primer. I got a set of used 23 x 10.5 rear tires and rims for it. The clutch assembly and some engine tin are the last of the yellow needing to go into primer. The mushroomed pilot came off easy enough reaming it with the handle end of a file.
It's gone much easier than I had anticipated. The parts it's needing are few and relatively cheap. I hope the engine goes as well as the chassis.
Old 06-14-2013, 02:24 PM
fleetlines's Avatar
The bearings and seals came today. I'm still running a few parts through the electrolysis tank. The engine is going to get painted as well since I don't know when I'll be able to get it machined or replaced. I'm wanting to shoot paint this Sunday.
Old 06-17-2013, 12:28 AM
fleetlines's Avatar
It rained a little this morning and looked threatening half the day so I decided it should wait to get painted. I had wanted to get pics up tonight of all the parts in paint. The new bearings and seals are in and I'm done with the electrolysis tank. I picked up a set of front tires in very good condition at a yard sale yesterday for $10 and they even had the tubes. I still need to get the seat and deck welded though.
Old 06-17-2013, 01:45 AM
fleetlines's Avatar
Most of the parts are hanging in the wood shed where they will be set to dry but a few still need gathered together.
Some shots of the frame repair done by a PO. I want to cut the angle iron off that hangs down but I'll need to stay away from that weld.
I rattle canned the places on the parts that meet and won't get paint after I close up the transmission for the painting. Soon the fun part can begin - assembly.
Old 06-17-2013, 06:46 AM
Thanks for the pics and update! Looking good!
Old 06-17-2013, 07:48 AM
PaulS's Avatar
PaulS PaulS is offline
Looking good Curtis. Looks like my garage with 102 parts all in prime.
Old 06-17-2013, 11:21 AM
Nice work, Curtis!
Old 06-19-2013, 11:37 PM
fleetlines's Avatar
I managed to get in the first coat of yellow. Instructions on the can said to let it fully dry before the second coat.
Using a new gun I thought the gun wasn't working right. Managed to get a few runs before chasing down the problem. I lowered the air pressure the other day when I got rained out and must have raised it when I filled a tire. Thinking it was still at 50 lbs. I found it at 85 today. I must have gave it a little bump to speed things along there. The gun survived me disassembling it several times and is working well.
I'm using Majic paint and it flows well and has good coverage.
Old 06-19-2013, 11:48 PM
C5rider C5rider is offline
Looking great!
Can't wait to see it all together! But I'm sure I'm not the only one.
Keep up the great work, and if possible, keepin' us informed of the progress.
thanks!
