Old 06-09-2013, 12:33 PM
Originally Posted by mike melillo View Post
Has anyone seen a conversion to convert a standard 2 port lift valve to a 4 port for the front accessory ports on a wide frame series?
I'm considering the modification, but I would only do it if I could find the parts to do a clean install.
Mike
Are you asking about converting the spool valve? In hydraulics, the amount of ports is not what you go by, but the spools in the valve. Are you saying you want to go from a single spool to a 2 spool valve so you have the front remote outlets?..... Or are you wanting something different?
