Old 05-29-2013, 10:03 PM
garnold's Avatar
garnold garnold is offline
Default Do I have to adjust my clutch?
I really have to push down on the brake pedal to disengage the clutch. In fact a lot of the time I still get some grinding of gears. Do I need to adjust something?
Old 05-29-2013, 10:26 PM
Dane in PA Dane in PA is offline
I'm having the same issue with my Cadet. I set it to factory, but it likes to grab too much... I think I might need to pull it again and clean it up some more...
Old 05-29-2013, 10:32 PM
vartz04 vartz04 is offline
Needs adjustment or repair. If you've never repaired any of it Ibet it is in pprettysad shape
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 05-30-2013, 12:22 AM
Sounds like both of you have a warped/ bent pressure plate. You should probably have the PP faced.
Old 05-30-2013, 10:09 AM
garnold's Avatar
Is there anyplace I can learn more about how to do this? Any chance there might be a nice willing senor tech around NJ that would be open to teaching a (young at heart) lover of these tractors?
I have no idea why I have grown so attached to this +40 year old tractor (maybe because it was built the same year I was born) but it's clear that I have HAHAHAHA
Old 05-30-2013, 01:58 PM
Not really, you have to have it done at a machine shop. It will either need ground, or faced with a lathe.
Old 05-30-2013, 03:28 PM
ToddW's Avatar
ToddW ToddW is offline
think the same thing is wrong with my 108
Cub Cadet 108, IH snowthrower, IH ?? mower deck
Cub Cadet 1650, IH 44 mower deck, IH snowthrower
1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake
1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow
1953 Ford Jubilee tractor and F100 Pickup
Old 05-30-2013, 03:47 PM
TommyK's Avatar
TommyK TommyK is offline
Garnold and ToddW, if you remove one of the panel extensions (i believe you're both talking about a 108), you can see if the clutch plates are disengaging properly when you depress the brake pedal. With the tractor off and the brake pedal locked on, you can check if the rear clutch plate moves freely. Could just be the rear clutch plate hanging up on the roll pin. Garnold, if you can get your tractor up to CT, i'd help you with your clutch.
Old 07-16-2013, 07:48 PM
garnold's Avatar
So now mine won't even disengage Even if I push the pedal down it does nothing. If I start her up with it in gear it will actually start moving even with the clutch pushed down. TommyK I might actually think about heading up to CT.
Old 07-16-2013, 08:52 PM
jimbob200521's Avatar
Another couple things to check are the throw out bearing and the drive shaft flange. The flange has a small bearing in it that can give you grinding gears, had the same thing happen on my 1050. Ended up replacing everything from the flange back to the throw out bearing. Otherwise what others have said, make sure your pressure plates are faced and good to go.
-Ryan
