Old 01-23-2010, 07:12 PM
02dmaxx 02dmaxx is offline
Default Some homemade stuff
This was a walk behind Allis-chalmers tiller That I Adapted to my sleeve hitch(wich I also made).
Extended tine
Old brake rotors off my '02 2500 chevy
Old 01-23-2010, 08:58 PM
Good work 02dmaxx, cool stuff!
Wish there were more threads like this.
Old 01-23-2010, 10:25 PM
Now thats some fine engineering there 02dmaxx.
All those pieces look really great.
Old 01-24-2010, 12:37 AM
Awesome job, 02dmaxx! I really enjoy your pics.
Old 01-25-2010, 03:33 AM
johncub7172's Avatar
Right on! cool man!
Old 01-27-2010, 09:20 PM
cadetfarmer cadetfarmer is offline
Default Cool Stuff
Nice work there 02dmaxx;
I love building stuff for my CCs.
We need to see more of this on this site.
CadetFarmer
Old 01-28-2010, 06:27 AM
drivadesl drivadesl is offline
Very nice work 02dmax. It all looks strong and very functional. If I may ask, about the tiller tines. What material did you use, and how did you bend the curve to the final shape. Did you have to heat treat following bending? Also, I like the wheel weights. You must have a pretty good size lathe to cut the rotors to size. Would you mind explaining the process as to how you made these. Thanks and great work.
Old 01-28-2010, 03:26 PM
Thanks. The tines were cut out of 1/4 inch plate with a torch(with the arc shape) and bent in a vise with heat and a 3# hammer. No treating was done to them and I haven't managed to bend one yet(hooked some pretty big roots/rocks).
The rotors happen to be the exact same size as the wheels,they fit right inside the lip around the wheel quite snug.I just cut a circle out of a piece of 1/8 steel and welded them in the centers,which it just so happens the welds cracked (steel to iron). I used some pipe,1/2 I.D. and the depth of the rotors over two of the existing lug holes and filled the rest with concrete.Originally the weights could be mounted the other way,so they wouldn't stick out so far,but I beefed up the mounting stock and now they hit.
Old 01-28-2010, 03:27 PM
CadetFarmer
Working on a FEL now.And you are right,I to like to see what other people can dream up.
Old 04-13-2010, 12:58 PM
that tiller is sweet! like you, i make-do with what i got, not rush out and spend on rubbish.
