Is there a dye or colored hydro oil that can be purchased? I have a leak on 1450 #1 and I can't find where it's coming from. Appears to be the right front/side of the hydro, but I'm not sure.
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift. ![]() |
As a suggestion.....you may want to take something like "brake cleaner" and clean your Hydro until there is no dirt or oil. Once the unit is sparkling clean, then monitor and watch for the oily residue.
I don't know of any type of fluid to do that what I would do is get it clean then get baby powder and sprinkle it a round area and you will find the leak
If it were leaking from the check valves or input shaft then it should be obvious, providing it's half-way clean.
If it is leaking from somewhere else... Then it has to come out to stop the leak. If you were taking it out to replace a seal or gasket, then you would probably replace all the seals and the gasket while you have it out, that way you won't have to take it out again in 6 months to replace something else... So take it out and replace the gasket and the seals (except the one on the trunion shaft), then you can put it back in with confidence.
![]() Quote:
I've had them leak on the trunion shaft as well. The side that you have to pull the shaft out to fix is a pain but not extreamly hard. I'm betting its coming from that area
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
![]() Quote:
And I should have said "unless it really looks like that is where it's leaking".
My 2182 had a leaking trunnion shaft seal. This is the thread on the re-seal.
http://www.onlycubcadets.net/forum/s...ad.php?t=21261
Thanks Ray, I'll try the baby powder.
Finally found the leak. Mowed yesterday and lost a lot of speed and she started bucking. Cleaned her this morning, got carried away w/ the power, but found the leaks.
2nd leak is the front hydraulic couplers. Installed new o rings, be they are still leaking. Any ideas? I have 2 new couplers, but from what I see, they will be a pain to change out.
