Old 05-12-2013, 10:51 PM
Thanks for the videos!
Old 05-14-2013, 12:38 PM
JK777's Avatar
JK777 JK777 is offline
Thanks for video and very cool.
What are you going to do about a hood?
Old 05-14-2013, 12:51 PM
Dane in PA Dane in PA is offline
Thanks Guys, I should be getting some attachments to run soon and I'll try and get some video of it mowing and eventually plowing snow!
I'm going to run it without it until I can work out a new location for the fuel tank and muffler. I believe this uses a pressurized fuel system, so I don't think I can use a different tank.
Old 05-14-2013, 01:15 PM
jbrewer's Avatar
jbrewer jbrewer is offline
I might suggest putting a plate of some sort between the mounting nuts and the bottom of the cast (aluminum?) block of the new engine. Otherwise I'd be concerned about the vibration grinding away at the block.
Other than that, it looks GREAT.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-14-2013, 01:18 PM
John
There is no vibration between the two and I tighten the bolts before I run the machine while I'm checking the oil and fuel, but I am looking into buying rubber washers to put between the motor and mounting plate.
Old 05-14-2013, 04:04 PM
Oh-ho, the mods might have to change the title of this thread to
"Quiet Line Cub Diesel Repower"
with those rubber mounts under the engine!!
Old 05-14-2013, 05:54 PM
There is nothing "Quiet" about this Diesel-Knocker!
Old 05-14-2013, 06:12 PM
Not sure I'd put rubber under the mounts with a belt drive, how do you keep it tensioned? Think you need to get used to shake rattle and roll.
Old 05-16-2013, 08:10 AM
rdmanone's Avatar
rdmanone rdmanone is offline
Very nice job. The video's were great.
1975 CC 1250
CC 1650
1979 Snapper 1855
1973 Wheel horse 12 Auto
1984 Power King 2418
1967 Simplicity Landlord 2012
1968 CC 149
Old 07-23-2015, 01:20 AM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
Any updates on the build?! This is awesome and I would be very interested in trying to duplicate this. Is this a Kohler diesel?
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
