Old 05-01-2013, 06:50 PM
cub-ed cub-ed is offline
Default 149 Drive Shaft Pin
I ordered a new drive shaft for my 149 with a new pin, it came with pin installed and, for the life of me without getting carried away, I can't remove it to install the cooling fan for the hydro, any suggestions?
Old 05-01-2013, 08:25 PM
vartz04 vartz04 is offline
get roll pin punches, put it in a vise, and smack the crap out of it.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 05-01-2013, 08:55 PM
I was worried about smacking it to hard, I'll get right on that though, I knew it was a tight fit but didn't know it was as tight as it was. I'm actually quite surprised, the old pin had worked itself out and ended up trashing the drive hub and shaft. I'm glad that it is as tight as it is, does anyone set these with a loctite or any other product to prevent backing out or is just friction between the two enough.
Old 05-01-2013, 08:57 PM
That pin is not a spiral pin it is a hardened steel pin, no need for roll pin punches...
I usually close the vice enough to lay the shaft on top of the jaws and let one end of the pin go down between them (the jaws) then smack the other end of the pin with a good heavy hammer.
Old 05-01-2013, 10:07 PM
Fantastic I will conquer in the morning, will keep you posted if there is any issue.
Old 05-01-2013, 10:42 PM
Don't forget to wear your safety glasses!!!
Old 05-02-2013, 03:36 AM
cubby102's Avatar
cubby102 cubby102 is offline
One you get it out and are ready to reinstall try putting the pin in the freezer for. Bit and heat the shaff up a little. Then once that's done slide the pin it. Might make it a little easier
Old 05-02-2013, 05:34 AM
Fantastic idea will attempt!
Old 05-02-2013, 08:55 PM
Success! I'll have the tractor running tomorrow, break in the rebuild, rototilling and mowing!
Old 05-02-2013, 09:19 PM
COOL, nothing like a happy ending! Run it hard to break it in and give it an early oil change and she should give you many years of service.
