Old 01-19-2010, 09:10 PM
transformer transformer is offline
Finally got em out but one....I had to use a ez out on two but the last one broke the ez out off just above the top of the bottom set screw.....I think this is the most annoying thing Ive probably ever done.Right up there with the time I dropped a small socket down my freshly built big block chevy...
Old 01-19-2010, 10:06 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
It gives you quite a sense of accomplishment when you finally get it off there. Sounds like you ain't quite accomplished it yet though. Good luck with that easy-out! They are some really hard metal. Hope you can wiggle it out of there.
Been there on the dropping parts thing. Put new Bilsteins on my 2500HD recently. Dropped a socket, and spent more time finding that dang thing than I did putting on all 4 shocks! At least I found it... The funny part was that I dropped it AFTER tightening the last bolt on the last shock, so I didn't really need it any more.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 01-20-2010, 03:49 PM
Well I finally got it off...From the looks of it someone had put blue locktite on the set screws... I noticed that when I took a good look at set screws I managed to get out.I had a friend that owns a tool a die shop and he gave me tip on how to get that broke ez out out. He told me to go get a cheap carbide tipped masonry bit.Looks like a paddle on the end and use it to try to get the broken ez out out....and it worked like a charm...I was skeptical when he said it but I tried it and it worked...Fell like I just won the loto...
Old 01-20-2010, 04:59 PM
I've done that before with broken taps, but until now would never admit to it.
