Old 04-30-2013, 02:51 PM
Peruvian Peruvian is offline
Default Steering issue - turning radius
I replaced the worn tie rod ends with ball joint ends on my 1450 last year. Now the turning radius is shorter to the left than to the right. Does anyone have a link or directions to setting this properly?
Old 04-30-2013, 04:00 PM
vartz04 vartz04 is offline
It has it in the service manual you can find yours in the technical library. More than likely you need to adjust the ends on the drag link not the tie rod.
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 04-30-2013, 07:17 PM
You turn the Steering all the way right (or left), then count the number of turns to go all the way to the opposite.
Turn the steering to mid point of that number.
Unhook your drag link and adjust so the front wheels are straight forward at Mid Point of the steering wheel. Then reconnect the drag link.
