Old 04-20-2013, 01:36 PM
84Buckeye 84Buckeye is offline
Default 149 Driveshaft question.
Quick questions for you guys. Took the hydro pump out to replace the gasket and the 3 seals I could get to without taking the pump apart. During this fix, It became obvious how bad of shape the driveshaft components are in!
My next step is to put axle seals in and possible replacing the carrier gaskets too, then finishing the back end up by doing the disc brakes.
Then on to the driveshaft! I really only want to do this one time, and make sure it's right. Today I went to Case IH dealer and got a breakdown of the parts needed which include.
Arm $62
Flex Disc $23
Rod $66
Hub $74
Fan $12
Roughly $250. Not complaining about the price but I seem to recall reading a thread about putting a flex disc up on the engine instead of the stock hub. Point was, it much better setup. So when I buy a new rod/driveshaft, will I have to get the components installed on the flywheel, Flex disc etc. then measure and drill precisely where the 1/4" spiral pin will go? Doesn't seem like there would be much margin for error on this.
Thanks!
Old 04-20-2013, 03:25 PM
clint clint is offline
I Would go with OEM ( the way it came from the factory) I have a 149, and no vibration problems. Also shop around parts tree, and check the sponsors.
Edit make sure you get a new fan, and new spirol roll pins ( I used stainless heavy duty from McMaster) and anti seize in the holes, and on the bolts etc... everywhere
Make sure the connections to the pump have not worn, the stub shaft that sticks out of the pump, and the coupling. I have seen these parts get "walled" out and cause vibration issues, also the same attention to the engine side.
Good luck
Old 04-20-2013, 06:20 PM
Thanks Clint.. yeah pretty much everything is bad. The part off the input shaft is 'walled' out badly. Hub attached to engine flywheel has a grove worn in the bottom of it by the spirol pin, which is just about broken. it all needs replaced.
You get to 'fixin' stuff and more and more pops up. Which is ok because I want to keep this tractor for a very long time!
Just comparing which way to go with the driveshaft. Price wise they seem comparable. Just curious which would be the better long term fix.
Old 04-20-2013, 09:34 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
I bought a cub 149 in Feb. this year. It has the double flex disks on front of drive shaft. I am currently starting a mild restoration. Pretty new to the forum also and a complete rookie at this. I also have another 149 in pretty rough shape. It has the standard drive shaft hook up. After driving both of them, the one with the flex disks in front seems a lot smoother when going from forward to reverse and back. Don't have any idea how it would hold up.
Going to try to attach pictures of the one with the flex disks. It looks like a special flange has been welded to the front of the shaft and the dowel pin is not used. Good luck with your 149 project.
Bob
Old 04-22-2013, 05:08 PM
There's a small nub on the end of my driveshaft, or what used to be a small nub, it's pretty much all gone now, at the end that connects to the hydro, is this what was used instead of the 5/8 steel ball? Mine didn't have a steel ball, just wondering if it's just missing or was never there to begin with?
Old 04-22-2013, 11:05 PM
I believe the nub that you refer to is supposed to go into the "back half" of the coupler, to center the shaft.
Quiet Line tractors were the first to use the 5/8" ball.
Old 04-22-2013, 11:59 PM
Darrell Darrell is offline
Mr Bob , You need a longer driveshaft for the tractor with the flex discs , or something else is wrong in there. The discs are not supposed to be bowed out like that , they should sit flat.
Old 04-23-2013, 06:28 AM
Thanks Sam!
Old 04-23-2013, 07:27 AM
sawdustdad's Avatar
I converted my 149 to use a flex disc at the engine end. You just need the drive flange from a QL (instead of the drive hub), two short carriage bolts, two hex head machine screws (all 3/8) and locknuts, a flex disc and the drive collar (two hole flange) that pins to the driveshaft. I got the parts from ccspecialties.org, one of the sponsors. assemble everything, mark the driveshaft for the pin hole, then remove and drill a 1/4 inch hole for the spiral/spirol pin. I reused my existing driveshaft. Seems to work fine. If you use two disks at the hydro end it would change the shaft length.
Old 04-23-2013, 11:06 AM
Mr Bob's Avatar
Default 149 drive shaft
Darrell
I looked at my drive shaft hook up again and it looks like when the flange was welded to the drive shaft, it was welded too far back thus twisting the discs. It seems to operate smoothly but do you think it will stay together? I have only moved the tractor on and off the trailer and rode it into the garage. It came with a 54" snow blade and I believe that is all that it was being used for by the previous owner or owners. Thank for your input.
Bob
