Old 04-07-2013, 08:55 AM
Grampie Grampie is offline
Nice Job so far there Mark! Good to see your getting it whipped back into shape! It'll be a nice tractor when your done and well worth the effort. You might want to consider upgrading your front axle to a newer style with a pivot bolt & castle nut verses the old pivot pin and the larger 1" spindles. Just a twist of a wrench and no axle slop and the larger wheel bearings put an end to those issues also. I did this on my 149 and very happy I did.
Old 04-17-2013, 08:53 PM
Stonewellmark Stonewellmark is offline
Finally got the 129 out to do some chores. Picked up the cart from a neighbor who built it himself. Its galvanized steel, needs a little tinkering but seems nice so far.
Mark
Old 04-17-2013, 08:56 PM
The 129 and cart look good Mark!
Old 04-17-2013, 09:04 PM
Stem1415 Stem1415 is offline
Nice 129! I have a '72 I just started fixing up.
Rob
GT's: 1972 IHCC 129, 1984 CCC 782
LT: 1991 MTD/CC 1415 with bagger
Farmall Tractors: 1947 Cub (I'm 2nd ower, 99% original with paperwork), 1946 H, 1951 M w/ SM kit, 1955 300 row crop. *Sold Tractors*: 1941 AV, 1944 BN, 1947 BN
Old 04-17-2013, 10:15 PM
Mark
Good looking 129 and cart!
Old 04-18-2013, 05:54 PM
cubcadet1650128's Avatar
cubcadet1650128 cubcadet1650128 is offline
will the narrow frame top casting work in the wide frames if modified a bit??
Old 04-18-2013, 09:35 PM
I have seen it done so anything is possible with modification.
