Old 03-31-2013, 02:17 PM
Originally Posted by timbo2 View Post
Thanks Sam,
I PM'd you my email.
I'll try it with the switch in run position then put the fuse in. I'm out of fuses for today unless I borrow from the 2284, since it's Easter I'm probably not getting more fuses til tomorrow!
Thanks!
Just sent it.
Old 03-31-2013, 03:35 PM
timbo2's Avatar
timbo2 timbo2 is offline
Thanks again-
More info for full disclosure-
At first it would start, blow fuse, but continue to run and run well, M20 sounded good.
had to replace fuse each time to start but it cranked up right away.
now it cranks but won't start
PO thought the Ignition module was bad and even included the new coil in the purchase. Engine sounded awefully good to me when it was running but I did replace spark plugs, oil, filter ect.
Have not replaced coil as it looks like i need to pull engine for that and that's a new step for me.
thanks again all.
- Tim
Old 03-31-2013, 03:42 PM
timbo2's Avatar
should add that I jumped the fuse to get it to crank but no start, don't want to do anymore jumping the fuse though- seems like a bad idea.
- Tim
Old 03-31-2013, 04:01 PM
Congrats on the 2082!
Old 03-31-2013, 07:41 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
My 2284 pulled a similar trick. It would run fine for days then just randomly quit running sometimes it would blow the fuse sometimes it wouldnt. Finally figure out the key switch was corroded. Unhooked it, cleaned everything on the switch and plug then No more problems.
Don Smith
Old 03-31-2013, 07:44 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Nice Super! Take your time, you'll find the short eventually. If it was running dtrong, the coil is probably not the issue. It doesn't sound like you've run it for long enough to get it hot, which is when those coils were more likely to fail under the resistance from heat. How many hours? If it's blowing the lights fuse right away, there has to be a short to ground somewhere in the lighting circuit. Patience, and you'll get it. If the coil DOES turn out to be bad, you can slide the motor forward to get the blower housing off, and also pull the driveshaft to flip the fan.
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 03-31-2013, 07:55 PM
timbo2's Avatar
thanks Tom and DS,
DS I have a newer ignition switch on my 2284 that I may swap cause that is on my list of suspects.
Tom - so I can just slide the engine if I detach the drive shaft and remove mounting bolts underneath? won't need a hoist/lift? I have a comealong but don't trust my ceiling strength yet to support very much and don't need a collapse.
Thanks again guys-
- Tim
Old 03-31-2013, 07:59 PM
timbo2's Avatar
oh forgot- approx 775 hours
- Tim
Old 03-31-2013, 10:46 PM
Low hours. You'll get the wiring fixed.
Old 04-01-2013, 01:31 PM
timbo2's Avatar
Todays update-
fuse blows when inserted if key is in run or run w/lights position.
I have removed blue light wire from ig switch and swapped ignition switch with a known working replacement same part #.
If I move thru the wiring schematic it looks like Coil or Alternator next on the list?
Thanks!
- Tim
