Anyone have the NAPA part numbers for the front wheel bearings? They are for the 1872. Thanks!
They should be the 1" size NAPA should be able to cross them for you, hope this helps. You can also google the part number. Cub part number 941-3002 Front Wheel Bearing Assembly. Replaces Part Numbers 00014550, 741-3002, IH-404836-R91, IH-60773-C91, WD-900-3503, WD-C38592 Price $19.35
Thanks Sam, I appreciate it!
Allen, the 1" bearings from NAPA are part# 7-08412. Are you getting ready for RNPD?
I have a 122 and the right front wheel eats bearings. I noticed that the wheel was loose, so I took the wheel off and found the outer bearing was nothing but steel pieces. Since then I have put two bearings in and both ended up separating the outer from the inner ring and ball bearings are everywhere.
bearing seems to fit snug inside wheel and around spindle. Any ideas? Thanks |
Both times I purchased the bearings from the Cub cadet dealer. Not sure how good that quality is though.- Any suggestions on other source for the bearing?
I have used two bearings on my tractors, the Cub bearings and the NAPA bearings. Two observations. I like sealed bearings better, but since most bearings are made in China, I don't trust the sealed bearings, because I can't see what lube was used. Also, the NAPA bearings that I used were just sllightly smaller in diameter than the cub bearings. They fit snugly by hand into the rim, but is not a press fit like the cub bearings.
Take your cub brearings to a NAPA store and ask them to cross referencwe them or measure the outer race. Then order a bearing or two based upon that measurement. BTW, I bought a cub bearing for my PTO. Put it on and had problems with PTO slippage. Opened up the PTO and found that the clear grease from the sealed bearing spun out of the bearing and coated the pressure plates, Instant slip. No indication of defect on the bearing.
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
where is a good place to get the 2"od 1"id sealed flanged bearings?
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood. |
