Old 03-12-2013, 12:41 AM
Default Wide Frame PTO Rockshaft
Can anyone tell me for sure if the front PTO rockshaft is the same between a brake type and a non brake type PTO on a Wide Frame tractor?
It seems like there should be some difference in spacing between the "tang" and the two types of PTO.
Old 03-12-2013, 11:44 AM
sawdustdad's Avatar
I can't answer the question directly, but I think I'd just use either the fiber button or the brake arrangement, depending on the rockshaft I had. My 149, for example, came with one or the other, depending on when it was made. My particular unit was a 1972 so it does not have the brake.
Old 03-12-2013, 09:30 PM
TommyK's Avatar
TommyK TommyK is offline
Sam, there is a difference between the 2. The hole where the brake shoe attaches to the rockshaft is recessed slightly on a brake type rockshaft. On a non brake rockshaft, that hole is flush with the rockshaft arm.
Old 08-25-2013, 11:27 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Along this same line, my neighbor down the road has a 169 with the Brake Shoe cup bolted to the PTO Clutch Rockshaft. However his 169 is missing the entire PTO pulley assembly, including the IPTO brake disc. I'm thinking he might save $75 by getting a non-brake style PTO pulley assembly but I don't know if a bronze wear button will fit the brake style PTO clutch rockshaft. Any ideas?
Old 08-26-2013, 12:48 AM
rweaver rweaver is offline
the arms and the hole to mount the brake are not the same the button type has a smaller hole in the arm
Old 08-26-2013, 10:04 PM
I removed the brake type from my 169 not long after i got it.
I much prefer the fiber button type.
I changed the rockshaft
You can see the arm is welded more on the front of the shaft in this first picture. its off of the 169.
This next picture is the one i installed from a earlier model Cub.
One on the left is the brake type. One on the right is the button type.
Old 08-27-2013, 11:55 PM
Those pictures are very helpful in describing the differences!! Great support Diz Jr.!
