Old 02-05-2013, 11:28 PM
mighty1206 mighty1206 is offline
Default 1782 fuel filter
I'm looking for info on where the fuel filter gets mounted on a 1782. I'm putting a diesel in a 2182 and not sure where the diesel fuel filter gets mounted.
Thanks
Old 02-06-2013, 01:12 AM
cub123's Avatar
cub123 cub123 is offline
Welcome to OCC! It's mounted on the left side, it actually should have two, an in line filter before the electric pump,then the cartridge filter before the injector pump. The electric pump is mounted under the engine mount, I think you can see it a little in the pic. We would love to see some pictures of your cub!
Old 02-06-2013, 06:09 AM
Thanks
Old 02-06-2013, 11:00 PM
Thanks for the Pic that helps alot! I will try to get some pics on here when it looks more like something.
I wish i wouldve known about this forum sooner, lots of helpful info on here
Old 02-06-2013, 11:31 PM
cub123's Avatar
Your welcome! You putting a D640 in it?
Old 02-07-2013, 10:06 PM
got a D722 for it
Old 02-07-2013, 11:01 PM
cub123's Avatar
got a D722 for it
That will be a sweet tractor! That should be an easy swap and you will have a 22hp diesel! Can't wait to see your progress!
Old 02-09-2013, 11:08 PM
Hopefully it works out. if the engine wouldve had the right front cover probably wouldve had it in tonight. This front cover has the oil filter on same side as injection pump. need to modify engine mounts.
Old 02-21-2013, 03:08 PM
How close does your air filter bracket com to your glow plugs? Mine are closer then what I would like to see. Not sure if these are taller.
Old 02-21-2013, 03:59 PM
cub123's Avatar
Mine bolts to the two eye loops for lifting the engine and sits above the valve cover. It should have plenty of clearence
