#61
#62
Send me a pic of what you have. My guess is you can get what you need at an auto parts store or plumbing supply
#63
cory, my original has a new piece of fuel line with the two nuts and fittings on the end made the line is made out of brake line the auto parts can sell u 2 metal ferrows instead of rubber grommets and it will work mine does not leak
#64
Cory,
My 100 leaked like a sieve between the fuel sediment bowl and the fuel tank. Tried everything - new bowl, teflon tape, then Permatex #2. Nothing would keep it from leaking. Then I used JB Weld. No more leaks. For what its worth.
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
#65
Well, I got it to fire off and stay running using another carb I have and gas NOT starting fluid. I got all of the leaks to stop except for the fuel bowl on the carb. It is leaking where the bolt goes in... I am just so frustrated with it at this point. I took the bowl out of another carb... one that doesn't have that little push button on the bottom because It was leaking from that. I got the fuel line to stop leaking and I bought a new sediment bowl.
I got the clutch disks freed up as well as the governor. Now I need to get a muffler because it is LOUD! Im just worried that the pipe that is there may not screw onto the muffler because they are all gone.
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
#66
Thanks for the update, Cory! You're making good progress.
