Old 02-01-2013, 11:13 AM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Thank you, the paint on my 1200 is the original paint. The guy I traded with told me his dad bought it brand new in 1979 and used it to mow with. He said it was only 5 or 6 years after his dad bought it that it started running rough so instead of fixing it his dad parked it in barn for 12 years. After his dad passed away he said he took it and just parked it in his shed and never messed with it cause he had a zero turn mower and it sat in his shef till last spring when I traded for it. After I got it home I found out it was missing welch plug in carb and was sucking air. I rebuilt carb cause it was nasty from sitting, tuned up tractor, changed fluids, sharpened blades and put ag tires on it. All guages work which only show 489 hours and counting and front and rear lights work. I almost got a virtually brand new 1200.
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 02-03-2013, 02:17 AM
bocephus1991's Avatar
Good looking 1200 you got there! I have a 79 1200 also whats the serial number on it? mine is 650604. . Mine had a short block put in it in 96 I think it was,we didn't change oil like we should have it only has alittle over 360 hrs on it. It had sat outside some to so I restored it over a couple of years.thanks for sharing!
Brian
Old 02-03-2013, 08:39 PM
dirtcowboy's Avatar
Smile
My serial # for my 1200 is 650179. Its all original. Everything works great.
Old 02-10-2013, 06:23 PM
425 apart! Pretty close Thanks!..Brian
Brian
Old 02-10-2013, 07:38 PM
bolivier's Avatar
bolivier bolivier is offline
Sure wish my 1650 looked that good!!!!!!!!!! Sweet tractor. I'm going to have to get me some tires like those. Completely changes the look of the tractor.
Old 02-11-2013, 08:54 AM
IMO you did well on the trade, got the better end of the deal.
Old 02-11-2013, 09:50 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
sweet deal. very nice looking 1200.
Doug
Original , 100 , 125 , 582
