Old 02-02-2013, 09:27 AM
Tim.E's Avatar
Tim.E Tim.E is offline
Default carb "spacer" gasket.application?purpose?advantage?
What is the application/purpose/advantage of the carb "spacer" type gasket over the plain single layer thin gasket? I am changing the carb from a walbro to a Kohler Carter # 30 on a K321 engine from a 149,and I am trying to determine which gasket to use.
My K321aqs has the spacer type gasket,but my k241's and k301's have a thin gasket.
Thanks.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 02-02-2013, 10:02 AM
cubs-n-bxrs's Avatar
I have gone both ways with and without the carb spacer and really didn't see any notable difference. I think the pullers run a spacer and it probably makes a difference on a modified motor. I beleive it has something to do with atomizing the fuel but not 100% sure. Sam Mac will know more about this topic I'm sure.
Old 02-02-2013, 10:22 AM
The "thing" that I have always heard, the spacer helps reduce heat to the carb reducing the possibility of boiling the fuel.
Old 02-02-2013, 10:33 AM
That is the best reason to use the spacer.
Old 02-02-2013, 10:58 AM
cubcadet1650128's Avatar
cubcadet1650128 cubcadet1650128 is offline
the reason for the carb spacer for pulling is because the carb vapour locks and wont run.
Tags
carb spacer
