Old 01-20-2013, 07:34 AM
rmunro's Avatar
rmunro rmunro is offline
The engine oil dipstick tube is loose. I tried to check the oil, and the whole thing came up. Is that just a press fit?? Oil pours out now when running.
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 01-20-2013, 07:52 AM
steve59's Avatar
steve59 steve59 is offline
Yes.....It's a pressed fit. Take it out and clean the area that presses into the block and put some Permatex Form-A-Gasket No. 2 Sealant on it.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 01-20-2013, 08:18 AM
rmunro's Avatar
Thanks Steve. Will try and get at that tomorrow.
Old 01-23-2013, 09:59 AM
rmunro's Avatar
Well, only had time for a quick look at the 1450 the other day. Maybe it's supposed to be a press fit, but this one literally will just drop onto the hole. Somebody has bucksheed a bracket that is useless, so this looks to be an old problem. I don't know if it's the wrong tube, or something is missing. Probably won't get back to it for couple weeks.
Old 02-01-2013, 02:59 PM
rmunro's Avatar
Well, got the oil dipstick tube anchored and sealed.
Still have major leak apparently from other side of engine. Hope to get at that this weekend.
Then tackle the hard start issue. Set timing, carb, new fuel filter may be all it takes.
The engine is loose and can be moved around. I think they have bolted cradle solid to frame, at least no sign of ISO mounts.
Bouncing back and forth between it and 1210 I bought same day.
