Does a 682 not have a ported pump? I have a 682, and I have a 1711 (without a motor) that I was going to make an articulating one from. And was thinking I would put the hydraulic lift from it on the 682.
No the 682 wont have a ported pump but the 1711 should have one.
Other than that, is the 682 & 1711 rear the same? Same gear ratio? I don't need 2 ported rears on the articulated 4x4, I may use one in the 682.
The only difference between the two would be if your 682 is IH or CCC built or not.
If it is IH built it will have the cast rear and if it is CCC built it will have the alum rear but the pumps are the same. |
The 682 I have is IH built & I think it has an aluminum rear. The 1711 is CCC built. It's rear is different material?
An IH built 682 should not have an aluminum rear. Quick ways to tell include are to count the bolts in the hitch plate. Aluminum rears have 5 bolts and cast rear ends have 3. The back cover in an aluminum rear end would have an x-pattern in it with no oil plug. Usually, cast rear ends are the same color as the frame and aluminum rears are black. That is a quick way, but beware, during the transition phase of IH to CCC, there are black cast iron rears.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
Here is the rear of the 682: (Yeah I know I made the hitch plate wrong)
![]() And here is the rear on the 1711:
Those are the same transaxle...the 682 is CCC built.
Ah. How come it has IH logos all over it?
CCC used all the IH leftover parts.
