Old 12-04-2012, 09:43 AM
garnold's Avatar
garnold garnold is offline
Originally Posted by ToddW View Post
Nice looking 108!
I have one also, and they are tough machines
just upgraded to headlights myself (came off a 149)
Very happy I made the upgrade
Is that a cut hole in the top of the hood so you can add gas without lifting up the hood?
Have not seen that mod before
I didn't cut that hole. Do most 108's not have this hole cut out? My gas cap extends out above the hood so I don't see how this would work without the hole cut.
So you got the light kit from a 149. What is actually needed? Do I have to get a whole new grill or just pop out the top eye sockets? How about wiring? Is it just a standard harness that I plug into and add the lights and switch or is it more involved?
Old 12-04-2012, 10:44 AM
Originally Posted by garnold View Post
WF = Wide Frame?
Squeezing power plants in between the frame rails?
Please don't beat me up here, just trying to learn the lingo
This should help. From the tech section of the site.
http://www.onlycubcadets.net/forum/showthread.php?t=20
Old 12-04-2012, 10:47 AM
garnold's Avatar
Yep the pretty much spells it out now doesn't it HAHAHA. Thank you!
I like the idea of the wider frame than. As already mentioned it should make things easier to work on. Any reason to not like this?
And for the second question, what was meant by this power plant stuff?
Man I'm so digging this tractor! Went onto Craigslist and found a bunch of them. Have to control myself!!!!
Old 12-04-2012, 11:00 AM
With the NF you can't install a larger engine then a 12 without cutting the frame. The 147 was the only NF that had this mod dome from the factory. The 82 series allow for even more access.
Old 12-04-2012, 11:04 AM
garnold's Avatar
OK good deal. Don't see me changing engines anytime soon but glad to know that working on this old girl will be a little easier for this new guy
I thank you for taking the time to answer my novice level questions. I don't mean to be a pain to anyone or pull the collected IQ of the forum down to much
Old 12-04-2012, 11:07 AM
No worries! We've all had to start some place. The thing that makes OCC great is our great members helping each other out.
Old 12-04-2012, 02:32 PM
ToddW's Avatar
ToddW ToddW is offline
the hood has no hole for gascap on standard 108's. You must have a differnt tank on there from prev owner
I bought off fleabay a working pair of headlights/rims and sheetmetal panel that bolted right in when I removed my non-headlightpanel.
I needed to also buy a vintage cub cadet light switch.
you neeed to add wire and inline fuse, and tie into the ammeter to power the headlights. there was sa diagram posted a few weeks ago for 108 wiring if you search the threads on here
Cub Cadet 108, IH snowthrower, IH ?? mower deck
Cub Cadet 1650, IH 44 mower deck, IH snowthrower
1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake
1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow
1953 Ford Jubilee tractor and F100 Pickup
Old 12-04-2012, 03:11 PM
I love how IH changed the design from narrow frame to wide frame for ease of working and not having to cut the frame for a larger engine, but I grew up with a NF and enjoy it. I love having a 147 with a cut out for a larger engine. To each their own.
Old 12-04-2012, 03:18 PM
garnold's Avatar
Totally makes sense These things are such a blast to play around with!!
Old 12-04-2012, 06:14 PM
They sure are.I am still trying to make up my mind which one to use this winter for plowing and throwing...so many choices...
Up to 534 and counting...
