Old 11-21-2012, 11:34 AM
2cubcadets 2cubcadets is offline
Default Engine builder
I am needing a engine for my 100. I found this site on the web Kustomsmallengine.com. Has anyone done business with this site?
Old 11-21-2012, 04:10 PM
David a Calkins David a Calkins is offline
Default engine builder
do a google ,and see what you come up with ,a complete rebuild will cost you ,around $300.00 too $500.00 in parts and labor ,if you have it bored and have the crank turned ,and valves done ,and head milled ,hope this helps .David
Old 11-21-2012, 07:26 PM
Default Engine
Well I don't have a complete engine
Just a block,head, flywheel,carb
Old 11-28-2012, 01:29 AM
Wow! you get off cheap, try and double that price around here. 75 miles any direction from here is $700 to $1,100, but you will find the one guy who will do it in his spare time for $300 to $500, but he had all the wrong answers to my questions.
Old 11-29-2012, 06:45 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
that is pretty cheap. I get $550 - 600 for a rebuild with aftermarket parts. that includes a crank grind, boring and valve seat cutting. OEM kohler stuff is getting pretty out of line with pricing
Old 11-29-2012, 07:59 PM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default rebuild
Having my 10 hp Block bored out now at a machine shop for $35, if he can clean it up he will put a new sleeve in it and make it standard again, order undercut valve for $53 and new valve guides for $24 going to get a after market piston and gaskets for $59, we put it back together myself, the last rebuild was 7 years ago, not to bad for my puller with a LP Head and 18 hp cam at 4000 rpms. pull from 40 to 80 times a year
Donny
