Old 11-25-2012, 11:10 PM
cjet69's Avatar
cjet69 cjet69 is offline
Default Wheel Weights for the 1450
Since we picked up a front blade earlier this year I thought I should add some weight for plowing snow, if we get any. I looked around the shop and found some farmall front wheel weights. 1 pair from cub and another that fit a C, H, or M. I got them mounted today. The total weight is 128 lbs. The extra weight sure makes the tractor feel different. I'm now looking at a couple options for chains. Do you think this will be enough weight?
CC 1450, 44A deck, #2 tiller, 42" plow/blade
CC 124
CC 1220
#2 Cart
Old 11-25-2012, 11:53 PM
Have you added fluid to your tires yet? What's your drive way made of? You might need to add some chains as well.
Old 11-26-2012, 12:36 AM
Nice weights! They look good on your 1450!
Old 11-26-2012, 01:35 AM
cjet69's Avatar
No fluid in the tires. There is still some room for some 10 in. dia weights underneath these if I need them. The drive is mostly crushed gravel, but we have a concrete pad in front of the shop that will need plowing also.
CC 124
CC 1220
#2 Cart
Old 11-26-2012, 01:40 AM
cjet69's Avatar
ACecil. And since they are IH brand weights they will work better than some off brand weights.
CC 124
CC 1220
#2 Cart
Old 11-26-2012, 05:49 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
yep chains is always needed. some get by with out them. my 582 does good with out chains but when I put a set on it'll push 2' to 3' of fresh snow like its not even there.
with out them I need to ram it till the tractor stops then back up and hit it again.
but I only had 40lbs in each wheel 2 years ago and got no snow last year.
this year is the test (if there is snow) 95lb in each wheel , going to try with out chains first. I have 75lb JD weights in the 882's wheels pushing a thrower. I shouldnt need chains for that. but have a set just in case.
Doug
Original , 100 , 125 , 582
Old 11-26-2012, 10:55 AM
cuber cuber is offline
Put some fluid in the tires. Loaded tires make a huge difference in how the tractor handles!!! Washer fluid is a cheap way to go. I have washer fluid in a couple of my tractors, BIG difference!!!
Old 11-26-2012, 12:30 PM
Well, since my cub has NO weight other than the driver, I'm going to say a whole heck of a lot better than mine!
Old 11-26-2012, 02:34 PM
ToddW's Avatar
ToddW ToddW is offline
I have a blacktop driveway about 500 feet long-there is some incline to it.
I have fluid in my 108 cadet tires, and a set of weights. I am afriad to put the chains on because I hear chains will ruin blactop
Cub Cadet 108, IH snowthrower, IH ?? mower deck
Cub Cadet 1650, IH 44 mower deck, IH snowthrower
1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake
1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow
1953 Ford Jubilee tractor and F100 Pickup
Old 11-26-2012, 03:07 PM
cjet69's Avatar
I would prefer adding more weights rather than adding liquid. as far as chains go I've been looking at these.
http://www.millertire.com/products/t...2-tire-chains/
http://www.superior-tech.com/terragrips_01.php
CC 124
CC 1220
#2 Cart
