#21
Mike,
Since you have some experience with creepers, do they make a weak spot on the driveline if they are NOT engaged? I may not be making myself clear...... I have ready many places that the creepers will break if you use them in a high torque application like pulling a heavy load up a hill with the Creeper in the LOW side. My question is, if the Creeper is NOT engaged and you are pulling something heavy up the hill is it STILL a weak spot? I am a little unsure if the power goes through the creeper even in the HIGH setting. ![]() I hope that makes a little sense. Regards, Brad |
#22
The first tractor I had a creeper gear in was a 108. It was near new and I had transposed a14 hp QL engine into it. I used to drag logs, pull cars and one time I even tied it off to a Kubota diesel tractor on pavement to see which tractor could pull the other backwards (I lost). I didn't need the creeper for more power, just used it to relieve strain on the clutch. Never seemed to hurt a thing and I still have the gear in one piece almost 40 years later. As I mentioned before, I did shear a driveshaft pin or two. Maybe that is the actual "weak point" in that driveline? That's not to say that your intended use won't cause problems. I have no idea, only my past experience. Until I read this thread, I'd never heard of the creeper gear being a "weak spot" in a Cub driveline. Also, I don't agree with the idea that running your Kohler engine slow pulling a moderate load will cause it to overheat as long as the engine isn't lugging. Looks like you already have the answer to your situation. You can do one of these four things: Use your Cub "as is" and modulate the throttle for your desired ground speed. Install a creeper gear in your Cub and run the engine as fast as you think is necessary and select the appropriate gear. Use your 107 and don't have as much fun. Use your off brands that are already geared for what you want to do. Whatever you do, don't pull a trailer that is heavier than you can safely stop it. With a Cub 100, I wouldn't think that would be much weight and keeping that thought in mind, I don't think that same weight would hurt a creeper gear. Your 100 has internal brakes and if you get one rear wheel light, you can lose all braking action instantly. My advice is worth exactly what it cost you. |
#24
In case it wasn't made clear earlier in the thread, the creeper still connects the engine to the transmission regardless of whether the creeper is in high or low, so the weak point is there when the creeper is in high, as well. |
#25
![]() Like I said, the jerking back and forth can tear up anything. A dead pull, not so much. A '39 Ford three speed transmission would take 1000 sustained horsepower but and 85 horsepower flathead engine could tear one all to pieces by jerking on it. I'd agree the creeper is not built as heavy as the trans/rear end. I'd also think that IH would not design something to put in these tractors (creeper) that would break. If you're gonna' use some kind of hot rod clutch, don't know. Anything could happen. The only thing I ever had break was the driveshaft pins. To me, that is the weak point. |
#26
I agree with Matt the creeper it self is the weak point. Lots of parts to break inside and trying to locate them isn't cheap or easy. With that being said it's your stuff use how you want to use it.
There's no need in or
#27
You bring up an excellent point though...the clutch spring gives the input shaft bearing on the creeper a hard life. Using a stronger spring would shorten the life even more, which is another reason why my plow tractor does not have a creeper- the 800 lb/in spring would make me go through bearings like crazy. |
#28
Thank you very much for the thoughtful reply. Real experience is worth a LOT these days. It seems much mis-information gets circulated and repeated. Pretty soon it is accepted as gospel. Many thanks, Brad |
#29
The original poster asked what his options were to pull a wagon, not be under full power, max driveline load. I tried to supply him with some of my real world experience. He said nothing about pulling a plow. Or any other ground engagement device. I've had my creeper gears in hard spots. Never a problem. I just tried to relay that to the original poster instead of getting all wound up in "weak spots" and other such rhetoric about a Cub driveline. You input to the original poster I don't believe was helpful at all 'cause he's not pulling a plow. Just to try and see if there's any validity to what you say about "weak spots", I did a casual search here and tried to find someone who had a creeper gear fail. I didn't find any but I only checked several pages of search. In any case, either you just like to argue or this forum is like a lot of the rest of them. My way or the highway. You (and someone else) on the other hand wanted to take it to a different level for what reason, I have no idea. If you have credible testimony of creeper gears failing pulling wagons, please direct me to the appropriate thread! |
#30
Ok guys time to drop it. Any more and I'll close the thread.
| Tags |
| 108, creeper |
