They are likely stronger but will wear the hole in the coupler and driveshaft because they are not a tight fit in the hole. They used spirol pins for a reason...
If I didn't have to be able to remove it I'd use the spirol pins, they fit the bore a bit tighter and my 71 will never see much hard work. It's just a play toy. It may pull a lawn seeder.
Looks like Matt and I posted about the same time with about the same answer.
Spirol pins it is! Lol, do either of you know if you can use the pins that are just 1 round of steel instead of the spirol looking ones? I can't seem to find spirol ones any place other than CC.
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
Mid West has them
Spiral Driveshaft Pin 1/4” X 1 1/2 “ Long Priced Individually Prt No. SP1 $1.85 I think I remember Matt had a place to get them even cheaper.
Those are great, we use them in our pulling tractor. We also just use grade 5 bolts instead of 8's. They are a little softer which lets them give without snapping under great load. Also it does help to slide a 1/4 punch in to help line everything up first and then drive it out with the pin or bolt. They do make special punches for these, the have a small dimple on the end to help it stay centered on the pin. Midwest does have a lot of good stuff some is good for stock mowing the lawn stuff too. They have kevlar clutch disc replacements that are quite nice as well.
Just curious, any idea why the creeper has the breather extension? The rebuilt one I bought has the stubby factory one.
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
McMaster Carr is a good place to get the coiled spring pin.
I get them from there and buy them in a 25 piece bag. I can't seem to find the part number right now though!
