Old 11-23-2012, 09:42 AM
340demon's Avatar
340demon 340demon is offline
Default gas cap
Hey does anyone have a measurement, or tell me how to tell what size filler opening I have on my 1250? Went to finally order one last night the one the PO had on there has never fit right. Come to find out there is a large and small neck size. I'm assuming it's the large, but anyone know the measurement the caps have the gauge on them so want to be sure before i order. I believe it is the original tank. Thanks for any info.
Sam
My Cubs
108 & 1250 & 104
Tiller, snow thrower,
Plow
Old 11-23-2012, 11:50 AM
Should be a filler cap (gauge) part number IH61635-C3
That's the only one shown for replacement.
Old 11-23-2012, 02:53 PM
340demon's Avatar
Sorry was not sure where to post. Thanks Zippy1, was on CCspecialties site and they listed the same part # you posted, but they had a IH109037-C2 for a Quiet line series w/ a large filler hole. Both are 6" in length with gauge. That's where my question started from. LOL I assumed the Quiet line series would all be the same. Thanks was just trying to make sure I had the correct cap size. I will order the small one. PO has one on there but believe it is not the right fit.
Sam
My Cubs
108 & 1250 & 104
Plow
Old 11-23-2012, 03:34 PM
I just checked Parts Tree and they gave the same numbers for all QL tractors.
I didn't know there was different sizes of caps, but they show only the one part number. Hope it helps.
Old 11-23-2012, 05:21 PM
340demon's Avatar
Yes it does help thanks. Don't know why they list that but guess I am going with the small one. Thanks again for the help.
Sam
My Cubs
108 & 1250 & 104
Plow
Old 11-24-2012, 05:51 AM
cdlong's Avatar
cdlong cdlong is offline
There are two size caps per several of the sponsers. Check the threads on the gas tank. My cap didn't fit correctly either and I cleaned the threads up with a small general file set from Harbor Freight.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 11-24-2012, 07:35 AM
340demon's Avatar
Ok I will take some pics of my tank and filler neck. And post measurements of ID of filler neck to compare some. I just want to be sure I have the small neck before I order.
Sam
My Cubs
108 & 1250 & 104
Plow
Old 11-24-2012, 07:57 AM
I was always under the assumption, that the Q/L Series tractors used all the same gas tank. Didn't know of two different gas caps.
Old 11-24-2012, 08:22 AM
The gas tanks are the same but the fill neck is different on the early ones.
I think around serial# 560210 they changed to the bigger neck. Serial# 560209 and below had the smaller neck.
Pictures would be most helpful.
Old 11-24-2012, 10:00 AM
Mike that's some good info!
