Old 10-04-2012, 07:30 PM
Originally Posted by teejk View Post
you have a true wheel puller...most of us need something like that once in our lives! did you insert any bushings where the bolts hit the wood or are cranking on wood?
and I'll have to add that the QL series have a lot of stuff on the top of the tower (throttle, hydro, PTO switch). Dunno if something like that block would work.
All of those things can be removed to gain access. There are fender washers behind the nuts. As for the puller, it's cheaper than buying another wheel and box if you ruin either by some other means. You'll also find that puller is very useful. I use mine frequently.
Look at the dash.
Old 10-04-2012, 09:26 PM
Cub-N-It's Avatar
Cub-N-It Cub-N-It is offline
Wow, thank you everybody. Matt G, big thanks to you for showing me your wheel puller. I have everything but the Oak block of wood but thats no problem to get my hands on. I've got plenty of PB Blaster in the shop. It's good stuff. I had to use it this year to pull a flywheel off an old Onan 20hp twin. You guys are great, and have really been a big help!
OK, now where did I put that Dynamite???
Old 10-04-2012, 09:48 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Make sure to let the blaster have some time to work.....
It's not always fast, but it IS relentless.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-05-2012, 12:10 AM
bkw3614 bkw3614 is offline
When I put my steering wheel back on after rebuilding the steering column and sector, I used some anti-sieze grease on the splines; both on the steering wheel and worm shaft. I think that stuff saves a lot of problems if, for some reason, it would need to be removed again.
Old 10-05-2012, 11:54 AM
tractordude tractordude is offline
Originally Posted by ClickClickBoom View Post
Spray it with some PB blaster, and let it sit.
then, take the nut off, get a pneumatic air hammer - just put in a flat bit, or a tipped one that will fit in the hole of the steering shaft. Hit it with the air hammer, and then pull up on the wheel. Mine came off nice and easy, and the nut was pretty rusted since it didn't have the cover.
This works for me all the time
