I have placed a wheel bearing in the top of both 1450 steering columns. Neither is tight like the plastic bearing was. Is there a way to get these bearings tight other than expoxy them in? Center punch around the outside of the column?
Thanks
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
What I did was took some very dense foam and cut a washer to fit between then bearing and the bottom of the steering wheel. This helps to hold the bearing in place and gives a nice, finished look. A little bit of black silicone around the outside of the bearing and inside the steering column tube doesn't hurt, either.
Good luck. |
I'm also have problems with the front wheels. The bearings are snug, but not tight. I purchased 6 RBC bearings, RF122214PP, flanged bearings. The wheels are in rough shape. the old bearings were actually cracked in several places.
Problem with front wheels is the wheels. I cleaned them with brake cleaner and they look like they were used with no bearings in them. Front spindles are grooved also.
@ CDLong, On my 104 I wrapped several strips of aluminum duct tape around the bearing till it was built up enough. Works great,. Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck As you slide down the banister of Life, may the splinters point in the right direction .
Thanks Chris, I'll have to try that.
I made 4 small slots in the top of the tube with a hack saw, put in the bearing and then used an hd hose clamp to lock it in place.
