Old 07-25-2012, 12:07 AM
EricR's Avatar
EricR EricR is offline
Very nice work.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 07-25-2012, 12:34 AM
TheSaturnV's Avatar
Looking great, awesome to see these old Cubs get the TLC.
Old 07-25-2012, 05:36 AM
save_old_iron's Avatar
save_old_iron save_old_iron is offline
See you there later this week with my 104. First timer visitor. I'm only doing it for better access to painting the frame. Hope that's a good choice.
Sorry, too many paint fumes I guess.
If you do not learn something new every day ... you are not paying attention !
Old 07-25-2012, 11:27 AM
Great work! That should fix the problem for a long time.
Old 07-25-2012, 01:44 PM
Originally Posted by 105_Tom View Post
I've made a lot of repairs on Cubs over the last few years, but I was always hesitant to split a tractor. Things have been bad awful slow at work, so I decided to dive headfirst into splitting the early-build 125 (s/n 218313) to resolve the cork gasket issue and speed lurch issues.
The rear pulled easily and it was out within an hour. I can see why the speed lurch was soo bad; the cam plate is barely touching the damper springs and the guide pins are worn flat on one side and cutting a groove to the right to get farther away from the cam plate! The trunion bracket is worn on all corners and towards the front and rear of the tractor on the inside corners. I pulled the hydro unit off the rear end and gave it to Dad to weld up and mill back down to spec at one of the machine shops he does service for (wish I could weld; I'd learn to do this myself). Need to call the dealer tomorrow and order springs and pins and possibly the cam plate depending on price as there is noticable wear on the cam plate guide pin too.
The cork gasket should be straight forward and the rest of the hydro and rear looks fine, if not worn a little after 40+ years of hard use. Amazing how well these tractors hold up to abuse year after year.
I'll update after the trunion is milled right and the cork gasket is done. Also want to find some wavy washers to take up the slack behind the snap rings on the cam plate mounting bracket and trunion spindle.
If this goes well, the 100 splits next to get it's shifter replaced, then the 123, which may require a little more time due to some linkage issues.
What is the shaft coming out of the rear of the transmission with the hole pre-drilled in it for? Was there some kind of rear attachment for these?
Old 06-26-2014, 04:50 AM
What is the shaft coming out of the rear of the transmission with the hole pre-drilled in it for? Was there some kind of rear attachment for these?Cub Cadet 123
No there wasn't but it really does look like there could have been!
Old 07-04-2014, 04:55 PM
chris hall's Avatar
chris hall chris hall is offline
i need to split my 105 soon. my cork gasket is seeping and i am sure my trunnion plate is worn. great work on splitting your tractor.
