Old 07-11-2012, 03:52 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default 105 steering box mount twisting
Split the tractor,pulled out the old wiring,repaired the trunnion by filling with a mig welder and grinding back to shape,rebuilt the relief valves with new external o rings,freed up a sticking relief valve with PB blaster( hope that was a good idea),rebuilt the steering box, de-greased everything,rebuilt the front PTO,and replaced the drive shaft and its rag joint.
I noticed the steering gear box flexes the plate it mounts to when the steering wheel is turned with the wheels on the ground, and the plate has a small crack in it. My question is are there any reinforcement procedures or repairs beyond grind and re- weld ? Has anybody else found this problem ?
Sorry no pictures ,the camera went out of service the day I started this project.
Thanks
Steve
