Old 07-01-2012, 10:28 AM
bvillecadet's Avatar
bvillecadet bvillecadet is offline
Default Working on the 107
Started getting the 107 in working order. My son and I have been fixing things up. Got the mowing deck wheels put on and new belt. Works nice. We finally got the plow to attach, don't think we had the right frame so we bought some shackles from TS to extend the brackets so we can use the quick attach system. Then we had to move the lift arm forward so we could get it to lift high enough. Works great now and even graded the driveway (could really use some wheel weights now). We also adjusted the gear selector so now she stays in forward while driving. Got the new front tires from GCT Wholesale on and have the rears on order. They look cool. Now that everything is working order we'll start paint prep next. OCC has been a very great help thanks all.
1970 Cub Cadet 107 currently being restored.
Old 07-01-2012, 11:36 AM
Default cub cadet 107
nice cub cadet 107 keep up the good work
Old 07-01-2012, 12:04 PM
TheSaturnV's Avatar
Lookin' good, I'm going to have to do quite a bit of rigging to get my cut up snow plow to fit again. Thanks for the ideas.
Old 07-01-2012, 12:59 PM
Nice work bvillecadet
Old 07-01-2012, 01:06 PM
Great job! Keep the pics coming.
Old 07-01-2012, 01:11 PM
Thanks guys , boy sure isn't easy drilling that good old american steel from 40 years ago. I also had to shorten the frame rails on the plow and then grind new grooves for where it slides onto the tractor. Accidently grabbed the rail while hot and now have an imprssion branded in to my palm of the end. Ouch! all is good though.
Old 07-01-2012, 05:19 PM
Looks great! A word of caution- when you aren't using the PTO clutch it's better to leave it in the engaged position so the wear button doesn't wear out prematurely. They can be expensive to fix, something to watch out for.
Old 07-01-2012, 06:44 PM
Thanks I will do that right away. I didn't know.
Old 07-01-2012, 06:58 PM
122cub 122cub is offline
I'm probably going to sound silly but what button are you refering to?
Old 07-01-2012, 07:08 PM
I believe he's refering to the little brass(I think) button on the lever that engages the pto for the mowing deck.
